1954 Farmall Super H
Dean Olson
Hi Guys,
I have a 1954 stage 2 Super H that has the wrong carb on it. The choke is on the wrong side and the # on the brass tag is: 5098DC. I suspect it's an M carb. .
I have 3 donor carbs #'s: 361525R92, 356948R91, 357231R91. These will bolt up and the choke is on the correct side.
What little research I can find seem to point that these carbs are correct for 300, SM,& 400. This is per the carb rebuild kit #'s on this site.
I suspect I'll have to disassemble them and see what jets and Venturi they have?????
What size jets and venturi are correct for the SH/300?
Does the tractor run and act like it should? If so,just leave it as is. Don't worry.Why spend the money and effort?The 'correct police' won't arrest you.They would probably have a heart attack at my place. LOL!
I'm all about thumbing my nose at the correct police.
However this tractor sat for at least 10+ years after the previous owner passed. I bought it about 5 years ago. I got it runnng and found the clutch is about out. Barely functions. It would only run at one speed, no idle control.
I parked it and it has sat ever since.
I pulled the carb yesterday and freed up the throttle butterfly. Reinstalled and now have throttle control back. Runs great but is starving for fuel at anything more than half throttle. I have plenty of fuel flow to the carb.
It's time to rebuild the carb! Because I have these donors laying on the shelf I want to rebuild the he correct one.
