Kevin Richardson
I just rebuilt the Marvel-Schebler TSX carburator on my 1955 TO35 with a full carb kit. I finally got the engine running but it is having some issues.
At the lowest idle setting on the accelerator arm the engine runs a lot faster than it should at low idle. Also, the only way to keep it running is to feather the choke between 75 percent and full choke. If the choke is allowed to open fully, the engine runs rough and dies.
I am guessing that the need to engage the choke means that the engine is not getting enough fuel for the full amount air that is going through it.
I tried opening up the idle adjusting needle and the power adjusting needle past the one turn initial setting, but it seems to have no effect. When I turned the power needle all the way down, it ran out of gas and died.
Not sure what to try next. Any suggestions would be appreciated. Thanks.
