Well I don't want to pay the EXTRA $300 for the pulley so I have to get the press set up anyway, may as well just build it myself, at least I will know that part was done right.Truth be told, you're probably just as well off putting a new import pump on it. Any rebuild kit will probably be import anyway.
I will have to check in the morning, I see references to the seal and gaskets being available but not the shaft.I dont see a complete kit in parts books. However all the parts are available from Agco individually.
I see a water pump, (without pulley) I do not see a kit, I can get a pump off of Amazon for $175 shipped and it is likely the same pump.Korves has complete kit $169 plus frt. Hard to beat.
Price for the same product is absolutely the determining factor for me, I am on a fixed income and farming/ranching is just a hobby for me, I certainly do not make a profit from it.Korves has stuff not listed on their site, but I don't know if it's what you want or need. They're really good people and folks to whom you may want to give your business. But if price is your determining factor, I understand.
Sounds like you should be good to go then. I don’t know if it matters on which to put in first, I always have put the seal in first and had good luck that way.John down at Commercial Water Pump Rebuilders in Houston hooked me up for $119.50 shipped
This includes the gaskets, shaft, 2 seals (in case I screw one up) snap ring, the 4 screws for the back plate and a seal installation tool.
And instructions that contradict what I saw on YouTube, you are supposed to install the shaft first then the unitized seal.
It does matter if you use the seal installation tool provided by the seal manufacturer, it is made of plastic and could not withstand the force needed to drive the shaft into the housing.Sounds like you should be good to go then. I don’t know if it matters on which to put in first, I always have put the seal in first and had good luck that way.
Bailey @ Antique Acres
Correctly working injectors will have VERY LITTLE return fuel going back to the tank. Return fuel is the slow leakage past the needle lift piston/bore area. Too MUCH return means that injector is junk and USUALLY engine will miss on that cylinder.There are no return boots or lines on the injectors, there is simply a long piece of hose by-passing them, interestingly enough the injectors do not appear to be trying to return any fuel.
