1958 deere 620
I broke the clutch brake pulley arm Part number A6111R, there are a couple on ebay for a 620 part number A5529R. Does anyone know if the A5529 will work? And if not, where should I look for the A6111R? T.I.A.
Per the 620 Parts Catalog that is free to download on jdparts.com going to the parts catalog area
A5529R is for S/N: ( - 6213099)
A6111R is for S/N: (6213100 - )
So the answer would be dependent on your serial number, which is located just in front of the clutch pulley on the frame of the tractor.
You can also try a used parts store (like Worthington Ag Parts, John's Used Green Store, or oldjd4u.com)
Matt
The 58 year has the inspection window for the clutch. And there are some small differences for the clutch puppy brake linckage. It would probably work if you changed the pully brake linckage. The 58 has slightly different linckage as the 57. This is probably the different part numbers.
