Good Evening,
I have recently received a Fordson Dexta that is running. A few things I've noticed and had questions about. The lift pump is completely bypassed/disconnected, would that be because it was bad and forced air in the system? The preheat function is inoperative, the fuel line is gone that goes to the intake, and the heater plug element is broken when I removed it. I see a couple styles that apparently fit. One is shrouded and one isn't. It surges pretty good at idle, levels out at higher rpm. I have removed the wire filter from the governor to clean, it was hard with dirt. It also doesn't stay in 3/7? gear. I was wondering it if that was a adjustment possibly.
