I have 1960 JD 2010 that has transmission problems with the high range not working, but it works on the low range side. I can get 1st forward and reverse, 2nd forward and reverse, and 4th forward and reverse, but if I pull the lever straight down from park to: 1/2 3/4 5/6 7/8 gears it's the same as if I still have the clutch disengaged. I have tried adjusting the rod linkages and had no luck. I pull the top cover off the transmission and seen that the shifting forks are fully engaging the gears. I cranked the engine up and slowly engaged the clutch and the power is not being transferred to the high range gears through the synchronizer on the same shaft. How loose should the synchronizer clutch be? That's the only thing that I can find that wrong.
