1962 ford 4000
Roark Cox
I'm rewiring a1962 ford 4000 light industrial loader back hoe. It was converted to 12v by po. I have chosen to go with one wire alternator and need a simple wiring diagram. no lights, just a volt meter. Thanks Roark
run your wire from the alternator to the large post on the left side of the solenoid (as you stand in front of it), same post you will run your positive battery cable.
solenoid hot post that is.
then wire all loads off the side of the ammeter hooked to the alternator.
soundguy
