1963 Ford 2000 hydraulics quit
Yall, I need some help. The hydraulics on my tractor are not working. Theyve always been a bit sketchy, only lifting the implement in the last little bit of lever travel, but now they arent doing anything.
I did take the top cover off and replace the worn pivot pin and the leather/o-ring on the piston along with other o-rings. M
After cleaning, reinstalling, and replacing the fluid, it still doesnt work. The PTO works fine.
Any help or suggestions are welcome..!!
Thanks!!
I actually went through the top cover as she shows in her video, even used parts from their business.
At this point, I'm not sure what to do. When I open the plug on the hydraulic pump, there is fluid there, so I don't believe that it has lost its prime. When the engine is running, fluid doesn't really come out of this hole, it just oozes a bit more if you rev the motor up.
I would think that if the pump is functioning properly, it should spurt from this hole.
What are y'alls thoughts on this?
