Leever2000
Started and ran weekend before but now having problems starting. Has spark! New plugs, wires a year old at most and battery charged. Turns over just will not start.
(quoted from post at 09:20:45 11/12/19)
Wet,
Wet,
(quoted from post at 06:01:45 11/13/19) It ran well last weekend once got it started via pulling with truck and popping clutch. I've had the Ford for about 5 or 6 years and already have the Pertronix. The power been as expected when it is running? I use for plowing snow in the winter and during the other times it is used for gathering wood etc...? The external appearance and the number of hours on the proof meter are consistent with the overall condition of the tractor?
(quoted from post at 10:55:37 11/13/19)(quoted from post at 06:01:45 11/13/19) It ran well last weekend once got it started via pulling with truck and popping clutch. I've had the Ford for about 5 or 6 years and already have the Pertronix. The power been as expected when it is running? I use for plowing snow in the winter and during the other times it is used for gathering wood etc...? The external appearance and the number of hours on the proof meter are consistent with the overall condition of the tractor?
Approx 2970 hours will verify when get home and that sounds about right for a 55 yr old tractor. Average 50+ hours a year.
(quoted from post at 12:11:43 11/13/19)(quoted from post at 10:55:37 11/13/19)(quoted from post at 06:01:45 11/13/19) It ran well last weekend once got it started via pulling with truck and popping clutch. I've had the Ford for about 5 or 6 years and already have the Pertronix. The power been as expected when it is running? I use for plowing snow in the winter and during the other times it is used for gathering wood etc...? The external appearance and the number of hours on the proof meter are consistent with the overall condition of the tractor?
That is the second or third hour meter.
(quoted from post at 19:06:24 11/13/19)(quoted from post at 12:11:43 11/13/19)(quoted from post at 10:55:37 11/13/19)(quoted from post at 06:01:45 11/13/19) It ran well last weekend once got it started via pulling with truck and popping clutch. I've had the Ford for about 5 or 6 years and already have the Pertronix. The power been as expected when it is running? I use for plowing snow in the winter and during the other times it is used for gathering wood etc...? The external appearance and the number of hours on the proof meter are consistent with the overall condition of the tractor?
2623 hours
