Sean in PA
The post labelled 1 on the distributor cap is only correct if the distributor was installed so that the post marked with the 1 is where the rotor points when the number 1 cylinder is at the top of the compression stroke. The distributor can be installed such that the rotor can point in just about any direction so that marking on the distributor cap is only correct if the person that installed the distributor the last time took care to install it so that the number 1 post position was correct. The number 1 and number 4 cylinders are at the top of their strokes at the same time, but one is at the end of its exhaust stroke while the other is at the end of its compression stroke.
