1964 4000 stalls while driving
brickman
Couple of issues i just started having. First is tractor just dies like its out of gas while mowing. It starts right back up, then will do it again after a few mins. Second is when i start it up it revs way high then settles down to idle speed. Both these things just started, dont know if there connected or just coincidence. Any help would be greatly appreciated. P.S. the carb is a zenith, and farley new
overreving and settling, and dieing like out of gas, then restarting after a bit.. surprisingly can be.... beause it is not getting enough fuel.
during starvation the gov moight open up the carb.. over rev and settle..
Still.. at moment of death check spark just to rule out a bad connection like a faulty key.
if you have good spark at death, or are unsure. hotwire from bat to coil and see if it still stalls. if it does.. move on to fuel flow.
things to look at are tank vacume, flow to carb, and to check for excess liquid water that may be in the fuel, sediment bowls.. etc.
I had a very similar problem with my 1962 2000 Industrial. My problem turned out to be a short section of rubber hose connected between the steel fuel line and the fuel tank. The hose was old and kinked which severely restricted the flow of fuel most times. It would run fine for a while and then stall. Sit for a bit and then started right up only to stall again shortly after. I replaced the whole fuel line with a steel line eliminating the rubber and it has been fine since.
I don't know if you night have a similar situation with a rubber component, a clogged screen the fuel tank or some other fuel related restriction, but is sure sounds like what I had experienced!
Good luck!
Check to make sure your throttle/governor linkages are all free and you don't have a broken spring. If it revs up every time you start it up, I'd try to fix that first since the problem is repeatable and you don't have to be under load to test it.
When the engine is stopped, the throttle plate will be wide open as long as the throttle lever is pulled open a bit. This is done through spring pressure applied to the carburetor's throttle linkage. When the engine starts, the governor will pull the throttle plate closed until engine speed matches the throttle lever setting. It sounds to me like the linkage is binding so the throttle plate is slow to respond to governor input. That could also explain the stalling under load.
Looked into the fuel issue this morning. Started with fuel line at the shutoff. With fuel line disconnected from shutoff, fuel just trickled out. Looked in the tank and could see small amount of debris pluging the hole. Was able to use my modified snot sucker to suck it right out. Just got done mowing 3 acres with no trouble. Have included some pics, one is of what i found laying in the tank. I believe it is supposed to be over the outlet hole in bottom of tank. It was up twords the front of tank.
