Jedeye1
- Location
- St Anthony, Mn
Good day. Been fighting this one for a few weeks now. Bought this tractor a few mo ago locally. Brought it home, changed fluids, filter, flushed rad, new coolant, greased, replaced petcock, and replaced battery. Basic things to do for a new to me tractor. Always started right up (12v conversation), no choke needed. Ran it all around prior to putting in in service. Never missed a beat. Took it out to the property, and while using the brush hog after several hours of steady use it suddenly shut down- like the key was shut off. Never overheated. No sputtering, didnt act like a fuel issue, just shut off and wouldn't restart. Cranks all day long. Wouldn't start. Checked cap and rotor, points, etc. All looked good. Pulled plug and checked for spark. None. Checked for rubbed wires or anything obvious. Nothing noted. Coil + wire comes right from ign switch and is in tact. Finally got it to start and died right away. Walked away for 30 min, came back and more of the same. Might pop off for a few sec, then dies. After some back and forth I was able to get it to run long enough to load it and bring it home. Checked fuel system, have fuel to carb and know carb is sending fuel. Pulled intake hose just to ensure I didn't have something funky going on with the intake system. Still no start/no spark. Tested coil, had batt voltage @ +, primary was 4.9 ohms, secondary was all over the place. 8k,9k,9.5k. Checked and still had no spark. Replaced coil thinking secondary was shorted. Same result. Cranks, no fire. Checked and still no spark. Can get It to start at random and run for a few minutes, then die. Kept #4 on the spark tester to keep an eye on it and when it does fire, spark is solid, when it dies and only cranks, no spark. Cap and rotor were old but looked good. Replaced cap, rotor, plugs and wires just to update and to cross them off the list. Same problem. Tested stud coming out of distributor and the only time I have continuity is when points are closed, otherwise it seems to be insulated from housing. Checked for continuity from stud to condenser wire under cap. Everything checks the box. What am I missing here? Struggling on this one.
