1965 3000 SOS no go
I was doing some brush hogging when I hit a small bump and the tractor stopped. It does not move in any gear and the PTO does not turn. There are no broken part noises coming from the tractor. Any hint where I should start looking?
It's a good possibility the torque limiting clutch is bad they have a bad habit of shearing the rivets off. When this happens nothing will work.
AKU:
If you are lucky, the torque limiting clutch disc has failed. If you are unlikely, the transmission input shaft splines have failed.
Dean
