1965 5000 super major
I recently replaced the grill shell on a friends early 5000, with one from a 7000 and dry air cleaner. Let me see what condition the removed one is in, I don't remember.
If you prefer the old style tin on these tractors, as I do, or just want to keep it original here's what I've learned from working on them.
First off, the nose on a 4000 is the same as your 5000 if you want to expand your search.
A 4400 is also the same.
The nose from a 2000/3000 will also fit if you cut the valence off and weld some little tabs on the bottom to bolt it to the bolster.
I looked at your older posts and could see the leading edge of your nose is smacked in.
The trouble with these noses is you can't get in there to do any pounding on it due to that bracket I call the bridge being in the way.
If you are willing to do some tinkering, the bridge is just spot welded in and is not difficult to remove. I drill the spot welds with a 1/2" drill bit and take them out. Be careful to not drill too deep that you go through both layers.
Now you can get in behind the dented nose and do some pounding on it.
I am presently working on a 4000 nose and wanted to change it from gas to diesel.
I took the gas bridge out and replaced it with a diesel bridge from a junk nose. I also saved the extra bracket for the air filter.
I've been working on this here and there and just welded it this afternoon.
Here are a few photos for you.
Gas vs diesel bridge. Note the holes for the air tube are on opposite sides and the diesel has a bracket for the air filter.
Here is the nose with the bridge removed.
Easier to pound out dents with it removed.
Extra bracket for the air filter.
Here's how it looks now.
I will do a bit of grinding on the welds and re sandblast those areas.
A guy sure couldn't make any money doing this stuff but if you like to tinker a bit it is fun.
(quoted from post at 21:04:04 03/15/20) The OP title says 'Super Major'.
Ford kept some of the Fordson model names on the new model thousand series models in the UK for the first year or two as a marketing ploy for customers over there who were familiar with, and trusted, the old model names. What was sold as the 5000 in 1965 here in the US was being sold as the "5000 Super Major" in the UK. They were the same tractor, just a different name for marketing purposes.
I looked at that grille shell, it is straight, the aluminum top grill is in pretty good shape, and the lower mesh is usable. Air cleaner and pipes are there also. $100 and you pay the shipping, if you are interested.
