1966 Ford 2000 Headlights Wiring
Big_Guy
Hello,
New to the forum. Purchased a 1966 Ford 2000 last year and have been fixing all the missing & non-functioning items. Now that I have it charging correctly, I would like to put Headlights back on it. The wiring harness had some sections cut and spliced and I have repaired them by soldering in new wires. Thing is, I can't find where the wire for the Headlights leaves the main harness and continues forward to the actual fixtures. Can someone clue me in on where in the harness I should look so I can open up the harness and solder in some extension wire for the headlights.
Bruce
Rockdale, Texas
Guessing this is a C prefix s/n. Brown from key feeds lite switch. From lite switch is red and a blue/red. The blue/red goes to front for head lites. Should be bullet connection close to green/blue that goes
to temp sender.
FORD TRACTOR WIRING; 12V:
Tim Daley(MI)
Tim's schematic is for the pre-1965 tractors. Since yours is a 1966 model, it is completely different. Below is the correct one:
(quoted from post at 18:41:11 10/27/22) Guessing this is a C prefix s/n. Brown from key feeds lite switch. From lite switch is red and a blue/red. The blue/red goes to front for head lites. Should be bullet connection close to green/blue that goes
to temp sender.
Thanks, This what I needed. I'll look closely by the temp sender wire for where blue/red was cut off. Its a C series as noted.
Bruce
Thanks everyone, Headlights are hooked up and working just fine. Was able to find the female bullet connector on the harness. Everything went together just fine. Having them allows me to work into the early evening!
Bruce
Rockdale, Texas
