(quoted from post at 11:39:14 09/16/22)
(quoted from post at 07:49:45 09/16/22)
(quoted from post at 22:12:12 09/15/22)
(quoted from post at 19:18:35 09/15/22) On the side of the CAV injector pump that connects the fuel line from the fuel filter to the pump. the end that bolts onto the injector pump looks like a Banjo fitting with a banjo bolt thru it. There is a red fiber wsher on either side of the fitting. The short pipe that is made onto the fitting leaks at the connection. Looking for a new replacement line with the Banjo fitting on it. Can you help me?.
Is it a plastic line.
No, it is a metal line and the joint where it connects to the Banjo fitting looks like it might be a sweated fiting.
My recollection is Ford changed that line to plastic. There's probably a used one available, but buying a work hardened metal line isn't a good idea. If the banjo fitting is sweated on, you might be able to remove it, clean it up, and reuse it on a plastic line. Sounds like you want a new line and don't want to go through all this. You can call Messick's parts department and ask if a new line is available. They have pricing posted online but don't show any in stock. This might mean it's NLA. They'll need to know whether your fuel filter body is single or dual element as the line changes part numbers.
Ford also used an elbow on the side of the pump in combination with a metal line and crush washer in lieu of the banjo fitting style line. You might think about eliminating the banjo fitting line and replacing it with this.
First you're going to have to determine whether a new banjo style line is available and if not, then whether you want to build one. If not, then there's the option of switching to the second design, which is much simpler.
