i bought a decent 3000 over the weekend, has some wear and tear but seems like a solid machine, except for needing rear tires pretty dang soon.
i am making a list of things that need attention before i stick it down in the woods on bush hog duty for the foreseeable future clearing my home site.
the throttle needs some work, i have the shop manual on the way since this machine is different than the two N series i have. i want to replace some of the throttle linkage rods, and most of the locking clips for the linkages are missing.
one thing i noticed right off the bat, the throttle has an arm that pivots on a center bolt that appears to attach to the intake manifold the bolts is loose, and the hole it fits into is wallowed out, causing the arm to cock sideways and is wearing a groove in the intake. i suspect that is wear some of my throttle issues are coming from, plus if its broke it needs fixing now.
the bolt has some sort of locking pin on the back side, but i cannot get a good look or feel it well enough to see what it is. hoping i don't have to pull the intake manifold, but i may have to to make the repair
can anyone recommend a fix, or give some ideas?
i was thinking i may be able to add some sort of bushing to the hole to repair the wallowed hole.
