1968 4000 Ford Hydraulics Problem
Ed Pitcock
I have replaced piston o ring and b/u washer and other o rings I saw..Lift will raise and lower, but will not hold postion or height adjust...Draft lever is in "up" position.
Any suggestions will be appreciated.
Did you have the lift cylinder safety valve checked, I made an adapter and check them with a injector pop tester.... should open around 3000 psi I think....if it is leaking the lift will leak down and then correct itself sometimes called the hiccup. hth
