1969 4020 clutch
JamesJTX
Posted in JD forum also, went to move tractor felt like a bump
when pushed clutch in about 2 inches from bottom and will not
go into gear, will go to park but that's all, need help on fix if
possible. Thanks
Look up inside with a flashlight. Pull the clutch pedal forward with your hand. The throw out bearing should move forward, contacting the clutch fingers which in turn releases the clutch plate. The bearing needs to be greased periodically. If it seizes up, the fingers get burned off quick. The PTO clutch bearing has a grease zerk too. Grease both of them.
