1969 4020 loader plumbing
MTB
I am mounting a JD58 loader on a 1969 4020 syncro with single remote and without factory 3pt. I plan to run the return line to the filter cover. Where is the best/easiest way to connect the pressure side? Any fitting sizes would be appreciated, I would like to get the parts before I start taking it apart.
On that modle (console modle) I remove the hood and then remove the pressure pipe at the Priority valve back next to the dash area, and put a #10 JIC swivel tee in and re-attach the pipe, you will need to loosen the clamps and let it go forward a bit,then I have a short hose made up with a #10 JIC female end on one end and a 1/2" male pipe on the other and use a pioneer coupler on it to couple the pressure line to the loader, when you remove the loader you can unhook this coupler and just let it tuck in against the block out of the way.
When the loader is removed from the tractor. Don't connect the hydraulic lines together as open centered systems are.
On a 4020's closed system that would make a direct hydraulic"short circuit".
Good to see somebody making the best loader connection possible.
