1969 Case 580
Anonymous-0
On an older Case 580 with the torque converter, I drained the torque tube and the converter housing (two separate drains) when I added fluid at the dipstick no fluid found its way into the converter housing.Do I need to run the machine to pump the fluid over to thr converter housing section? ( I see no separate fill port)
Thanks John Mills
