1969 ford 3000 draft control?
I have a 1969 ford 3000 gas. How does the draft control work? Since my grandpa and uncle have passed away, I really have no one to ask.
The easy answer is which way should the lever be? Up or down? I use this tractor to grade the driveway and bush hog. While I have a 2 bottom plow, I typically use my Kubota for that.
It’s working now but I can’t seem to tell a difference which way it should be.
Thanks.
flipped up would put you normal or position control..... so the position lever will be incremental as it lowers and raises. your implement.... so YOU...get to pick the depth.
DOWN would put it in draft mode... so that now if you move the position lever just a bit down, the plow will then fall to the bottom and the tractor will then measure the amount of pressure on the top link through the draft spring.... as the the tractor moves forwards, the pressure that the plow put on the top link will now cause the plow to raise up.. so you continue to move forwards and keep moving the position lever down more and more... the plow now goes deeper and deeper... UNTIL the wheels begin to spin or tractor starts to bog down... then you move the position control back up just a bit and set your adjustable reminder set screw at that point... THIS way the tractor will allow the plow to run deep as possible short of spinning the tires or bogging down the engine.. which is the perfect plow point... when the soil gets light, the plow will automatically go deeper,, when the ground gets harder the plow will automatically raise up a bit so that the tractor continuously plows at the max depth short of spinning out or bogging down and killing the engine... so you are now free to try to plow in a straight line.. when you move the position lever ALL the way to the top, the plow comes up,, you turn around go back the other direction and drop the plow back down to the reminder set screw to put it back in the magic position again and let the draft control do all the hard work on depth control.. This does not work well in mud or sugar sand as you bury the tractor too quickly for the draft control to act... Most of your work is done in position control, but plowing is best done in draft control.
Now that being said.. the flow control knob can also be used to control how fast the tractor picks up so you can make the draft a bit quicker or a bit slower pending on your soil conditions thus the flow control knob is normally set to fast, but can be set to turtle or slow to make the draft pick up less quick.. ie the tractor starts to bog down and the draft pulls the light/ small plow completely out of the ground,, you probably what to slow down the flow control... If you have a long heavy plow with lots of bottoms, you may need the draft to move very fast to stop the tractor from bogging down, so a faster flow control setting is better in draft mode.
