Infidel556
Greetings all, first post here.
I have a 71' 2020 gas model. I developed a sudden knock in the engine, and in the process of determining what was the cause, I have dropped the pan and checked my rod bearings. Thankfully, that was not the cause, but a choke plate screw that got sucked into the #1 cylinder. I managed to pick it out of the top of the piston and magnetically remove it thru the spark plug hole using a borescope. All is good and now it is going back together. I did a test run and the noise is gone. Here is my issue...I have been told that the rod bolts are "stretch bolts" and can only be used once. That's fine, but the price that Deere is asking is $37 PER BOLT. Yeah, screw them....not paying that. I have attempted to find these, but have had no luck except from a Deere source, which thinks they are gold plated and made of moon unobtainium.
Does anyone have a line on a set of rod bolts for a 71 2020 gas motor. Serial # on side of block is 51TL027539T.
I have been told that I can reuse them, but when I called the dealer to get the torque spec so I could do my test run, they gave me the diesel torque spec of 70lbs, when it should have been 40-45. So they are REALLY stretched now and I am to weary to move forward with using them.
Any links or sites would be great. Thank you all.
Brad
Brad
