Beleiver69
- Location
- Alberta, Canada
Hey All,
What's your guys' thoughts on the case 1370 as a baling tractor and for field work? I already got a 60hp 3pt hitch tractor with a FEL for moving bales and yardwork so I was thinking of buying this one for baling and hay work as a work horse. I heard they shift hard, but I don't mind as I enjoy the case powershift. I had a 2390 and loved it. Biggest things I've read for this 1370 is do regular tranny oil changes. for example the case 2390 power shift would pile up if you didn't change the tranny oil every 200hrs. which is fine. And I also read that the cabs are loud, but I'm sure I can use some rubber weather stripping liner/silicone seals on the doors and windows to help with the noise.
Also I was wondering if I can turn up the fuel pump. The one I'm looking at is the desert tan so 1971-74 version and I guess the major difference between it and the white 1370s is a higher idle in the newer ones. Also something with the brakes and 10 more hp? Curious if I can just turn up the fuel to make it the same. Since they are both under rated from factory. Read somewhere they were closer to 175 pto hp rather than 155 pto hp.
TIA
TIA
