Case-O-Matic questions
dhermesc
I've been looking at a couple older Case 930s with Case-O-Matic - how do you use one - how does it work?
Is it like the Allis Power director (no clutch hi-lo) only with a torque converter to ease it into the high and low side? I believe I saw somewhere that it automatically kicks into highside lock when you press the clutch to shift from one gear to another? It also has something to do with the PTO?
We are looking at one primarily for haying - baling, raking and loading.
Case 930s were never factory equipped with a Case-O-Matic transmission. They had a rather crude selective gear, fixed ratio six-speed transmission with numbered slots on the shifter case.
There are no 9/1030 case tractors with com. The com came in the 800 then 7/830 models. The 7/830 can also have a dry clutch. When you push the peddle it shifts to com not direct and you always start in com. They are very similar to an auto trany in a car or pickup only with manual shift. There is no actual speed or Geer change, only the torque converter being locked or unlocked. In direct they pull like any regular clutch tractor and in com the converter allows slip so speed matches load to power. The pto is independent and live and not affected by the drive system.
Case had a lot of models and options that I always had a hard time remembering. But I do remember the six speed 930 which reminded me of the shift layout on Russian tanks but what the heck, it worked. Pulled a lot of heavy loads with them.
exactly.
i will add. like Jon says the torque converter is exactly like a car. it will slip just like a car. so a COMatic tractor can be idled down and depending on the gear, it will simply sit there like a car at a stop light. they do have a set of clutches (disc pack) between the torque converter and the transmission (regular 4x2 8 speed) so when you disengage the clutch pedal it cuts power to the transmission and stops the tractor so you can shift. this is all hydraulically actuated.
when starting out say with a plow in the ground you go in COMatic (torque converter mode) and once going and up to speed you engage the direct drive lever which locks the torque convert out so there is no converter slippage (like modern cars from the last 30 years do it electronically) then if you come to a tough spot you just bump it back to CaseOMatic mode and get thru it. CaseOMatics have a pressure gage so you know if the COMatic pressure is right and a temp gage so you know if the COMatic fluid is too hot (if you're doing too much in torque converter mode they will get hot, like a car). they will have a set of oil lines go up to and back from the radiator like an automatic car as well.
you will see some change in speed with the direct drive engaged. handy hay tractors as you find the right gear and bale in direct drive then if you have a heavy spot or big clump you can go to COMatic mode and ease thru it. pretty handy.
a couple things to watch. check the fluid (big dipstick on left side) for level and burnt oil and some ?? are known to have the clutch pack discs behind the torque converter warp some making it hard to shift (gears keep spinning some). like anything else they can be abused as well.
generally good transmissions and kinda neat. i liked the one we had and i could pull small trees out with no trouble. find a low gear and add some gas and let the torque pull it out (Be careful) i've heard that a diesel caseOmatic is a good set up for tractor pulling too.
Post pictures if you have some
good luck
<iframe width=560 height=315 src=https://www.youtube.com/embed/WNrZHxy84nU title=YouTube video player frameborder=0 allow=accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture allowfullscreen></iframe>
The ones Ive been around had that little pointer broke off so you couldnt tell what gear you are in. Kinda interesting the first time you run a 930 like that.
My brother had a 530 Case-O-Matic loader tractor. I never really liked using the darn thing. Only real advantage was while loading manure, very little chance of spinning the wheels. Tractor would just sit there helpless.
We had a 930 western with the hand clutch beside the left fender. Had the six speed the pointer was there or I would have never had the thing a gear I could use for a long time learning. With rice tires on it it would pull through anything unless it was sand then it was done.
Correct - this is only in the 730/830 we've seen. We've been looking at several tractors and I got confused on what we've actually been on.
There is an auction tomorrow that has a 730/830 that has been sitting outside - we are going early to try to turn the engine over with a breaker bar to see if its free. The 730 or 830 is more the size we are looking for to run with our 706 and Massey 1130. What happens to a COM that sits for 10 years?
This auction looks more like a scrap sale than an equipment sale. Everything has been sitting for decade exactly where the original owner parked it before he died. The family is now finally selling everything to close out the trust. I am assuming everything was running then - but current condition makes everything a project. Without any idea what condition it was in before it was parked we might get deep into to a project before we realize its hopeless. If the 730/830 isn't froze up I think its probably good (or was good) - it was his only loader tractor and he handled big round bales.
If you are looking for a project to work on, go for it. If you are looking for an inexpensive reliable haying tractor, I would think twice about it. This one could only be a parts tractor. You can buy 30 series Case tractors already in field ready condition for $2,500 to $4,000, including some nice 930 Comfort King diesels.
If it is a diesel it's not likely stuck and should be fine. Very rare for sitting to cause issues in the com, but Crack the plugs to check for water. There are 3 plugs under the trany/ rear end and one on the com and of course the engine. When you Crack the engine plug look for antifreeze as the o-rings on the sleeves can leak when they get old. If it's gas I would expect it to be froze up, but I'd not all other advice applies. They are about the best tractor for loader work made as they don't spin holes when loading and you can maneuver them very gently when needed and there is no clutch to wear out.
Our main tractor growing up. Two tricks in use to avoid gear grinding when shifting 4spd, idle eng down to where U can count fan blades(lol) and speed up eng then drop RPM,s before putting into direct drive. Durable trans that people loved or hated.
Good tractors but...the COM is no fun to run with cold oil. Won't shift at all. If it's a diesel, the heads are cracked. If the COM needs fixed, you've got a lawn ornament. I loved the one dad had when I was a kid.
AaronSEIA
The tractor sitting outside was a 930 it actually started, the transmission was locked up, rims rotted, tires were in horrible condition. Bought by a salvage yard to part out for $600. The 1030 that had been kept under a roof was in similar condition - except the engine was locked up. Sold for similar price.
