But a cracked head or loose liner would cause a positive block test… right?Your problem is more than likely the same problem as why the machine was parked in the first place, there has to be a reason it was parked, those were great dozers but were prone to the liners coming loose and the heads cracking should they get hot and have cold water poured in. have a Cat mechanic look at it for you..
AJ
So if thermostat is done I’d still suggest cleaning those cores as good as possible. Then going at the water pump it’s going to be kinda spendy you don’t want to throw a 1000 dollar pump in and find out you need to clean the cores at the end. I think you are right pump is where this is headed. But I have seen a lot come out of what was thought to be a clean radiator. And it help significantly
I had similar problems with my caterpillar d-6c . I had to replace water pump because it was weak impeller cat tech said and was bypassing water, also replaced radiator because rust and water deposits were restricting water flow. Those two issues resolved the problem and works great now! Just my two cents worth!I just looked closely at the image of the engine side of the pump housing. Where is the gear that meshes with the gear on the water pump?
Can you take a picture of the installation and what the locations are for temperatures you are measuring? Are you sure that the wax pellet on the thermostat is pointing toward the engine? Are you sure you have the right thermostat? There appears to be about a dozen configurations for the 3304 and different thermostat housings.At this point, I also think that something is stuck in there or that something is restricting the flow.
The bypass from the water pump to the thermostat housing had some weird temperature readings: 170°F on the side of the thermostat, 140°F on the side of the water pump, and 80°F a quarter way from the housing down to the water pump.
I have no explanation other than something is restricting the flow in that are, why else would it be almost 100°F cooler compared to the rest of the pipe…?
"I installed a thermostat similar to the one that was installed before."Yes to all your questions. Pictures are attached.
According to the service manual, there are two different thermostats. I installed a thermostat similar to the one that was installed before.
Not sure why there are two different thermostats in the service manual. It definitely only has ONE installed and not two like more modern engines.
you should be able to clean the radiator with it on the machine carefully with a Hotsy you might have to take the brush guard offNo I mean the temperature differential between the top and the bottom hose of the radiator. So the radiator inlet and outlet. I measured a temperature differential of 30-40F.
Which I thought is good?
Is there any way to clean the radiator without removing it?
Besides that I have no idea how to remove it, it looks like a major pita to get that thing off the dozer. Let alone to remove all those rusted bolts to get the core out.
230 is pretty much what I have if I don’t pay attention…. Couple more of those test runs and at some point I will also need a new head gasket…
If I read this correctly, the 153 F is located at the lower end of the bypass line and the 84F is located at the top of the bypass line. The top of the by pass takes coolant from the engine and bypasses around the thermostat housing. SO the bypass line should be at the same temperature throughout its length. When the thermostat is open, some of the flow goes past the thermostat and some goes through the bypass line. and it combines somewhere and goes into the radiator. I think there is something wrong in your bypass system. Have you checked that?Yes to all your questions. Pictures are attached.
Took the pipe out and checked it, it is basically as clean as it gets. Nothing was stuck in there…. Oooor it moved, well hopefully not!I suppose take the pipe out and clean it that is kinda weird does the upper end go to the thermostat housing? 175 or 190 thermostat should be fine 175 should improve the operation of it if you are having trouble how you describe caterpillar had options on thermostat based a lot on customer preference and where they were located. Some of these things got sent to Antarctica and others to Iraq. The USA is in a fun spot in the middle where it doesn’t really matter if the rest of the cooling system is working. A lot of those big ones won’t fit in the housing but one direction so it would probably be kinda hard to mess that up.
Do you mean with bypass system the pipe? There is a way smaller pipe -If I read this correctly, the 153 F is located at the lower end of the bypass line and the 84F is located at the top of the bypass line. The top of the by pass takes coolant from the engine and bypasses around the thermostat housing. SO the bypass line should be at the same temperature throughout its length. When the thermostat is open, some of the flow goes past the thermostat and some goes through the bypass line. and it combines somewhere and goes into the radiator. I think there is something wrong in your bypass system. Have you checked that?
Completely agree! It should be the same temperature. I checked the „big“ pipe. I haven’t checked the other smaller pipe yet.If I read this correctly, the 153 F is located at the lower end of the bypass line and the 84F is located at the top of the bypass line. The top of the by pass takes coolant from the engine and bypasses around the thermostat housing. SO the bypass line should be at the same temperature throughout its length. When the thermostat is open, some of the flow goes past the thermostat and some goes through the bypass line. and it combines somewhere and goes into the radiator. I think there is something wrong in your bypass system. Have you checked that?
This hose you are talking about in this post, did you investigate that further? Where dose this hose run to from? Is it part of the bypass system?4. The water pump is also my #1 suspect. There is a rubber hose next to the water pump. When the thermostat is closed, I can barely squeeze it. Once it’s at operating temp, I can easily squeeze it.
Is that normal?? Shouldn’t the pump be able to somewhat maintain the pressure even with the thermostat open?
Yes, the bigger one is part of the bypass system. The small one - idk.This hose you are talking about in this post, did you investigate that further? Where dose this hose run to from? Is it part of the bypass system?
