I have read several posts that are similar to the issue with my dozer, but not exactly - Hopefully someone will be able to shed some light.
As stated I have a 1972 JD 450B dozer. A few months back I had the steering clutches and brakes replaces - all works well.
Just recently the 450B started not wanting to shift into any gear (R/H/L) upon first start up. After it warmed up for quite some time it would go into gear forward and reverse. Then it got where the transmission would not shift into Forward until operating it in Reverse for a bit. Then a few days ago I was pushing some dirt and it quit going into Reverse or Forward. It acted like it wanted to shift but wouldn't move. Finally I go it to go into Reverse after letting it sit for quite some time and got it back to the shop. It would not shift into High or Low Forward.
I read in my Service manual about adjusting the free play on the clutch and made the adjustment to 3.75". I also checked the transmission pressure which is supposed to be 170-180 psi. The pressure I recorded was less than 100 psi. I did not check the pressure when trying to shift to high or high to low.
I hope I have provided enough info explaining the situation. If you need more just let me know. Thank you.
