1973 IH 674 Valve kit
jmill00
Does anyone know of a good source for a valve kit. Valves, Guides, Springs, clips and gaskets. The dealer wants over $500 just for the parts (Aftermarket not IH) and I was hoping to spend a little less than that.
IH 674 with C200 gas engine
Do you know if you need all that? Unless it's already apart and the parts inspected, you may be buying more than you really need.
(quoted from post at 12:58:41 04/09/15) Do you know if you need all that? Unless it's already apart and the parts inspected, you may be buying more than you really need.
Not really sure, but I'm am pretty sure at least one valve is hanging up until the engine gets really warm. Loudly clicking from the valve cover area. I would say it was a bad hydraulic lifter only it doesn't have hydraulic lifters. The clicking goes away after it warms up, but it still doesn't run well. I figured that on a 40+ year old engine, if I have to take it apart for one valve I might as well do a complete valve job. Problem is I can find lots of parts for the Diesel engines, but nothing for the C200 gas engine.
Well have you taken a compression test? Have you had the valve cover off to inspect things? The C-200 is a 4 cylinder version of the 301 engine. You may be better off get parts separate and look at prices for 301 parts. I would not order parts till I had it all apart and all the parts cleaned and inspected.
Hy-Capacity has the kit for $182.67. You will need to buy from a Hy-Capacity dealer. A lot of independent repair shops are dealers.
(quoted from post at 05:57:15 04/13/15) Hy-Capacity has the kit for $182.67. You will need to buy from a Hy-Capacity dealer. A lot of independent repair shops are dealers.
Thanks Cliff, That's what I was looking for. I am about ready to start troubleshooting and wanted to be sure the parts were available before I dug in. Do you know if that $182.67 is the retail or wholesale price. Probably double that from the dealer if it's wholesale.
