1974 John Deere Model 310
denniscl
I am looking for a used 1974 JD310 Backhoe Loader / POWER STEERING VALVE HOUSING, SHAFT and MOUNTING GASKET. Can anyone help me out?
Welcome to YT
What's wrong with the steering housing you have now? Steering valve type changed at serial number -163706.
If your tractor is below -163706 & it needs new o-rings due to internal/external leakage I'd suggest renewing them VS R&R of valve housing.
(quoted from post at 03:29:45 07/24/16)
Welcome to YT
http://forums.yesterdaystractors.com/photos/38330.jpg[/img.
The housing split, tried having the cast iron welded, cracked again. Also, the piston oring is broken.
There is a free parts book on the JD web with a cross reference . Odds are that several ordinary farm tractors used the same component .
