1975 Ford 4000
Doc Tazz
I have A 1975 Ford 4000 3cyl diesel, it had a right rear wheel seal leak it has wet brakes, I pulled the housing off and replaced the seal along with the outer bearing and race, put it all back together and now it acts like the brake is locked up, but if I put a little bit of throttle to it will move, not sure what's going on
Everything went back the same as it came out, the shim is between the axle and the thick washer, I'm just wondering if the place I had press the bearing on didn't press it all the way down, not sure if that would cause this problem or not
