1975 mod 4000 remote hydralic connections
Larry C
I have a 4000 f0rd year mod 1975 I want to put front loader on it. It has a valve in front of seat between your legs that is a two position valve . the decal says pull for remote ,and my question is can this power loader and if so where does lines come out to loader valve. thanks for any help. larry
Not being a Ford expert I can only give general info. On a lot of tractors that have a single remote 2 hyd. lines are run to the loader controls and the tractor remote lever is tied down to make a continous hydraulic flow. On another thread on here today someone said the Ford pump only had a 4 gpm flow which makes for slow loader work. A lot of Fords had a separate hydraulic pump mounted to the front of the crankcase with a separate oil resevoir, giving plenty of capacity.
KEH
