1976 Ford 6600
kumar
I am working on a 1976 Ford 6600 Diesel tractor, This tractor has a cast iron oil pan. I had to take the front part of the tractor off to remove the oil pan, can someone please tell me what the torgue is for the bolts that hold up the pan.
Hello kumar welcome to YT! The engine and pan are both flat machined surfaces so I personally would just go by feel, but that is just experience talking. I will attach a bolt torque chart you could go by. If the bolts have no markings I would tighten them to the 307A spec. Just FYI there is a Ford specific topic section here. If you want to try to post your question there you can find that section by using the ..Jump to or Hop to.. drop down at the bottom when viewing a post here.
Bolt torque chart
