1976 MF 230 steering help
I am back and looking for more information on the power steering assembly on a early Massey Ferguson 230. For starters when you google Massey Ferguson power steering housing or assembly for a early 230 you will see a lot of images but they dont match what I have . I am leaking fluid out of a bolt hole on top where there is 4-5 in a circle under the wheel and also where the shaft comes out of the right side the left isnt leaking . Does anybody know if I can buy a seal kit for this type power steering gear box ? Any help would be much appreciated I have inherited this tractor in the last few days now I am worried there is no info or options for this particular steering assembly. Any part numbers or manual numbers would be great
No I havent checked AGCO . When you are looking at 230 massey Ferguson power steering assembly / gear or column what I keep seeing isnt what I have . thank you for the suggestion
Here's the parts drawing of the power steering gear for the older 230's.
Does it look like what you have?
You can see it clearly at the AGCO site and get the part numbers.
Don't know if this helps, but 1090346m1
(used on a 135) might cross reference to
Omix-Ada 18002.03. I bought a seal under
the Massey Ferguson number and the
printing on it was c684 5 kcy 28 36.5
5.7/7.6 tto. It seems to fit good. It
doesn't seem to be leaking, but it has
just been installed.
