1st tractor
Cchaci
Just got a hold of my first tractor a Massey Ferguson
Looking to see if I can get any info
Diesel pto and 3 point work
Want to add hydrolics and front loader
Is this possible
Any info would be greatly appreciated
Not sure about your questions, sorry, but congratulations on your first tractor! I know the feeling, I just bought my first tractor, a Formal Super C, last Saturday! I love mine, and I am sure you will enjoy yours as well! John
You can probably find a small loader for that, but don't expect much from it.
The front end is weak, no power steering.
It can be tied into the belly pump with an adapter and chaining the 3 point down. It will be very slow.
Or add an engine driven pump and separate reservoir. Expensive unless you find used components.
Personally, I would leave it as is, use it for what you can. Then be on the look out for something a little bigger, with power steering, a loader already on it and properly set up.
That appears to be a French built Massey Ferguson 25. They are somewhat of an oddball in the U.S. and parts can be hard to find. My nephew has one. He may chime in here. Good luck.
Thanks. Is that a 25 hp motor?
Having trouble locating a manual also
I got the better end on a trade I believe, probably will just get a rake and a box blade to remove rocks that seem to keep growing every time it rains!
There is a selection of parts available in the UK, from this link, and they will ship to the USA if you are stuck!
Good luck, Jim
PS The MF 25 would be a bit on the underpowered side for a loader - wouldn't do much!
Malpas Tractors MF 25
