2-105 hyd. oil drain ???
Need help changing the hydraulic oil in a White 2-105. Is the filter the drain? Or is there a drain plug/plugs on the bottom of the rear end? Or does the rear end take gear oil and it is its own system? Any help is appreciated.
The rear end is separate and takes gear oil, yes. To tell you the truth, I'd have to look up how to drain the hydraulics. I know on
the 50 series Olivers you have to just pump it out, but that's a different pump in those.
