Paul C
We recently acquired a 2-135 white.The tach cable was broke when we bought it so I purchased and installed a new cable.When you start the tractor on idle it shows 1400rpm and when speeded up the rev's pick up normally.The tach will not register under 1400rpm but will fluctuate some on higher rev's it does not stay steady.Did I install something wrong or is there an adjustment somewhere?Thanks for any help.
I would say your tack has a problem. It is draging or sticking. This is probly the cause of the first cable going bad. If mine I would pull the tack and have it checked.
