2-55 water pump
Ward1989
I have a 2-55 white iseki motor water pump really loose but not leaking.Does anyone know where I can get one in a pinch tried all states don’t have one.Might try to limp through until winter and get mine rebuild if I can’t find one.
Tough find there. I'd contact an Agco dealer and if they can't get one or a kit, maybe they can do a search and see if anybody even has one.
Agco has the pump available and it costs $ 672.18 and they also offer a rebuild kit that costs $ 137.31 the kit does not include the bearings .The kit comes with a new shaft, Impeller, seal and mating ring and then new snap rings for everything. They offer the bearings though but they are $37.24 for the top bearing and the bottom bearing is $47.86 these are the prices from one of my local dealers . So the prices may be higher or cheaper depending on your dealer. Hope this helps you and if you need the updated part numbers let me know and I will post them for you
Thank you I will check into it.
