I bought a 2-85 White tractor and I am trying to find out what kind of transmission fluid to use in the (hydro shift) direct, over drive transmission. I was told I could use a car transmission fluid, is this correct? Thank you for any replies
Either one. The early manuals called for the equivalent of Dexron ATF or HyTran/HyGuard type hydraulic oil. There was an issue with bearing failure in the larger tractors due to ATF being too thin,so they went to hydraulic oil in those. Just make sure it's drained good and has a new filter so there's no cross contamination.
