Hello, I just replaced the rear axle felt seals and checked and tightened the rear axle bearings on my 820. When I pulled the back cover off I noticed that the pto shaft (inside) had some nasty chew marks in it. They seem to come from the ends of the pins that hold the little bevel gears in the differential. If I wiggle the big gear on the diff. with a prybar it seems to be fairly loose on the shaft. I realize this should be tight but what should I do to fix it. The proper thing would be a new shaft and gear, but they are not likely available anymore. Should I shim the gear tight on the shaft, weld the gear on the shaft (probly not the best idea), just leave it (it could have been doing this for years), or get the shaft built up and machined down to fit tight again. Any ideas??? Thanks for any input
