2 spool hyd. Valve on H
DTK
If I put a2 spool valve on my belly pump H can I use 1 spool
for single acting loader cyls? ( trip bucket style). Thanks DTK
(quoted from post at 06:29:57 04/18/13) If I put a2 spool valve on my belly pump H can I use 1 spool
Yes, there is something that will need to be changed on the spool for the acting cylinder, but the new control should come with what you need.
You can use a valve that is convertable from double to single.As I recall,all it takes is a plug in the correct port.Or you can run a hose from the 'unused' port back to the reservoir.
(quoted from post at 07:08:29 04/18/13) You can use a valve that is convertable from double to single.As I recall,all it takes is a plug in the correct port.Or you can run a hose from the 'unused' port back to the reservoir.
Thank you for clarifying that. Sometimes the picture is in my head, but it won't go out through my fingers to the keyboard.
