2 spool valve question 165 MF
I have my MF 165 home again. I have the 2 spool valve, with a trip bucket loader. I need a remote to operate a post driver. Can it be done with the 2 spool and keep loader operating?
Do you have the 2 spool valve that mounts on the top cover near the right front corner of the seat, the 2 spool valve that is under the left side of the seat with the levers to the right of the seat or a separate 2 spool valve that goes with the loader?
(quoted from post at 11:05:29 04/26/19) Do you have the 2 spool valve that mounts on the top cover near the right front corner of the seat, the 2 spool valve that is under the left side of the seat with the levers to the right of the seat or a separate 2 spool valve that goes with the loader?
Mine is 2 spool under right corner of seat. The left lever will lock in 3 positions, the right lever controls the trip bucket loader.
There are different types of that valve. Some have a removable plate on the right side and some don't. The plate can be removed and another spool added, if you can find one. If yours doesn't have the plate, you will have to revamp the setup.
