I have a two wire alternator on a ford 640. I do not have a key
switch but instead a simple push pull 2 post switch.
I believe the red wire from the alt. goes to the amp meter -where does the white from the alt. wire go? Thanks.
The way I have it wired right now everything operates fine except when i push the switch in with the tractor running the tractor keeps running. I have tested the switch and the alternator and they both are good. When the tractor is not running, the switch kills power.
