Geo-TH,In
My terramite has a 20 HP Kohler command with hydraulic lifters, over 2000+ hours. For some reason after it sits for weeks it only starts on the right cylinder for about 10 seconds before the left cylinder kicks in . Both sparks are clean so i discount a spark issue, There is only one carb, so I discount a fuel issue because it runs fine after a few seconds. I'm guessing a valve issue. possibly a rusty valve stem or a hydraulic lifter problem. Do you have a 21 year old kohler command with a similar problem?
When I have time and it warms up. i will remove the valve cover and observe the valves to see if one valve Is stuck open. MY Jubilee exhaust valve stuck open. I sprayed wd40 on the valve stem and inside the cylinder and put the pushrod back in place. After running on 3 cylinders for about 10 seconds the valve broke loose and ran fine.
