Steve (Tx)
2000 4 cylinder gas.
The tractor idles well forever.
After about one minute under load, either mowing or lifting round bales, the tractor sputters and dies. Choking helps for a few seconds.
I cleaned out the gas tank. It is a replacement, so rust is not an issue. The fuel flow is good immediately after the tractor dies.
I have replaced everything except the governor. This has been going on for about one year. I have adjusted the timing. Tweaked the carb backwards and forwards. New plugs, switch, and all electrical parts. New carb, strainers, etc.
I am stumped. Could it be a heat issue? The water pump may be original.
Any ideas will be appreciated.
Steve
Steve
