2000 loader front mounting bracket 656
Can't help you with locating them , but pictures from parts book shows what they look like. Item #9 is part number is 487011R2. Both sides are the same. You will probably have to fabricate something yourself using attached diagrams and doing some measuring on your tractor.
I have a 504 utility model tractor that has somewhat similar front brackets as you would need to build. Send me an e-mail and I will in return send to you many pictures that I made some years ago for someone who wanted to build some for his 504.
If you start with an angle iron about a 1/2 inch thick then lap another over it with the loader frame between them you will have it mark weld then drill bolt hole and done. On on each side. This is the easiest method to do it. IF you want them to look factory then you will need to heat and bend some 1/2 inch plate about 8 inches long then bend a second one about and inch or so longer to go over it. Then weld them together with the space for the loader frame between the 2 ends and drill bolt holes. May want to weld a brace under the lip of the bent 1/2 inch plate outside. It would go between the bolts vertically.
If anyone could take a close up picture of the mounts on there 656 utiliy to show were on the loader frame the mounts set that would be very helpful.
Email your phone number and Ill text you pictures of the mounts tonight or tomorrow. Depends on the weather and what time I get home tonight
Good news my friends i have been reunited with the OEM mounting brackets, So Happy! I was surprised on how thick the plate steel is.Thanks for all the help it sure shows how the farming community helps each other
I saw a set recently for sale on Facebook marketplace, but you have to buy the entire loader to get them.
Not likely you are going to find just a set of brackets in the wild. If anyone has any laying around they probably don't realize it, don't read this site, or don't want to sell them.
