Southern Ray
I guess my ABS module is failing. The ABS light comes on intermittently, mostly when the temperature rises above 90 degrees.
It rarely comes on between late October through late March, though again intermittently, only in hot afternoons.
In reading up on it and viewing the videos on u-tube I've come to the conclusion that is where the problem lies.
I have a Chilton's manual but it just says to take it to the dealer or a qualified technician.
In viewing the videos it appears my most difficult challenge will be loosening and removing the four screws holding the module in place.
In one video the tech had to disconnect all the brake lines and drop the entire unit and place it in a vise to remove two screws.
The many videos gives three TORX size, 8,9, and 10mm.
Has anyone replaced these units? I don't plan to open it up and re-solder the joints, just replace the entire module.
