2010 3 point bouncing
99RT
I just picked up a old beat up 60's model John Deere 2010 and one of its issues is the three point will begin bouncing once it warms up. I have not drained the fluid and replaced the filter yet but wanted to post up here and see if you guys had any ideas on the issue. If you keep using the three point eventually it will just not raise anymore but it works as it should when you first start it.
Bouncing(hiccupping) 3 pt is normally caused by faulty 3 pt rockshaft piston seals or leaking control valve. If you decide to R&R rockshaft housing remove cover under seat to be able to access a hidden bolt or line.
Technician at JD dealership where I was employed yrs back referred to linkage inside 2010 rockshaft as resembling a ""toy erector set"".
(quoted from post at 22:40:46 07/07/21) What configuration is your 2010? Row crop
or utility?
Any history on it?
Gas or diesel?
It is the utility configuration. I dont have any history on it. It is gas motor.
