2010 Industrial
Hello. 2010 with 720 loader and 93 hoe. I tried to put a ball valve in the line going to the hoe to shut off flow and it really loaded the motor down so I shut off tractor immediately. The line comes from power beyond port on the 720 valve, the parts diagram shows a plug so I assumed I could block it. What have I overlooked? The control valve and rotating vane leak pretty good, don t use the hoe much and this was a cheap attempt at slowing down the leaks.
(quoted from post at 12:56:39 04/19/23)
JD 2010 has open center hyd system which requires flow to be continuous via a looped hose & shouldn't be shut off with a valve
Would that machine have a ''stinger'' pump, and where would the reservoir be?
I am familiar with open center but assumed that the open circuit would be in the loader valve, I guess I don t understand how power beyond works. I still had loader function, just loaded down motor when I closed valve. To the other question, it has a Cessna front mount pump, tanks is on left side mounted to fender. Thanks
