2010 JD questions
First where do you check the hydraulic fluid level??? Is there a adjustment for the brakes they are a little weak? There is a small leak on the under side of the tractor looks like hydraulic fluid coming out of a plate with four bolts that hold it on ?? Just bought this tractor and going to start working on it a bit. I know these was problem tractors but i got a good deal on it. Going to use and then resale. Thanks
The hydraulic system uses the transmission as it's oil reservoir. There's a hex-headed plug sticking out of the tranny at an angle under the operator's platform... RH side, ahead of the brake mechanism. Fill 'till oil is level with bottom of opening.
Brakes are adjusted by moving the nut on the threaded rod connecting the "innards" of each brake to the lever beneath the brake mechanism at either side of the tractor to set the free pedal movement of each pedal.
Plate with 4 bolts under belly is cover under clutch housing. Oil dripping there could be engine oil or tranny/hydraulic oil leaking out of the pilot shaft area, or from the hydraulic pump that's up inside the "dry" clutch housing, or from the power steering line that leaves the pump or from some various other hydraulic and steering parts that sit on top/pass through the bellhousing.
I had one for 25 years, and I didn't think it was as bad as everyone says. The brakes were never very good. You can clean everything up, then remove the glaze from the discs, they will work for awhile. Then you just have to push hard.
