202 Stabilizers for 3 Point
BIG1RED9
I want to add stabilizers on my 202. It has the frame for a loader and backhoe and I am concerned that the brackets that come with the kit will not have the clearance to mount nor allow for proper arm swinging. Any input is appreciated!
If you are planning to use a stabilizer of whatever type on each side it
is essential that the bracket pins are exactly in line with the pins that
the front of the lower links pivot on. If not the linkage will probably
tighten as it is raised. If the loader brackets/frame is present it should
be possible to weld suitable pins with large heads to the frame or
fabricate further brackets to suit. Ideally the front stabilizer pivot
should be about 6inches outside of the lift arm pivot.
DavidP,South Wales
Thanks David. I also notice there are several types.
Flat bars as in this kit https://www.yesterdaystractors.com/Ferguson-TO35_Stabilizer-Kit-Heavy-Duty_231253XHD.html
Adjustable https://www.yesterdaystractors.com/JSA1003_Stabilizer-Bar_11566.htm?gclid=CjwKCAjwgOGCBhAlEiwA7FUXkrT7o1XzdA51l4gfkwI9P91Ofno8_t3hlbGho-pOM-8kXRwzYCMdARoCWPYQAvD_BwE
I also saw one made by the tractor owner. A nicely made setup that is adjustable and had lubricated balls ends, that the bolts would go through on each end. The end that mounted near the fender bolts was mounted vertical, but the one that mounted on the lift arm was mount horizontally with an additional bracket he fabricated. When I look at this home made setup, I don't see how the 3 point will be kept from swing right to left as the stabilizers will rotate.. back and forth, unless I am missing something.
Thank you for the help!
Hi. Not quite following your description. Do stabilizers need to be
fitted both sides for them to work? The linkage must NOT be tight
when adjusted. There must be a little movement.
DavidP
Picture of the described part.
The flat bar ones got bent pretty pad when my blade got stuck on a stump.
I upgraded to the adjustable ones in your second link, I had to drill them larger on the one end, and used a 3/4 bold on the loader frame as an attachment point, adjustable is much nicer when switching implements.
